rotary into dx.....
rotary into dx.....
Postby Low_Aa63 » Mon Nov 21, 2005 10:16 pm
ok ok before i start.. i have searched and searched and blah blah but search is crap (im probably just inept at using it) but i digress
Ok so im getting a dx and am quite keen on "putting a rotor in it au"
What im failing to come to terms with is the mounting of engine and box...
Ill explain myself....see what i was lead to beleive is that a rotary enginge sits quite low in the engine bay of said rotary so to transfer rotary into say a dx you would have to eitherslam the enginge and box crossmembers dangerously low to the ground or..... slant it down towards the back of the engine bay..
Im also after info and possibly pics of a finished conversion because (excuse my lack of rotary knowledge here but) i was under the influence that a rotary has no engine mounts that attatch to the enginge crossmember
Any help will be appreciated
thanks
Ben
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby ke_25 » Mon Nov 21, 2005 10:34 pm
try http://www.rotahavik.co.nz
they might be able to help you, try searching there.
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby Low_Aa63 » Mon Nov 21, 2005 10:41 pm
cool cheers
The list so far
Low_Aa63
Postby badidas » Tue Nov 22, 2005 1:10 am
www.rotor.tk my site
1989 mazda bongo aka [BNGBUS]
badidas
Users browsing this forum: No registered users and 54 guests
