Vertigo wrote:im going to run a tube to a mushroom filter, pointing up near the bonnet near the centre of the engine. i will surround this with a welded metal box, cut holes in the bonnet and mount a scoop.
Vertigo wrote:1. what tube should i use, where can i get it, and how much?
Vertigo wrote:2. weighing up costs and that im on a budget, and not looking for outrageous performance, should i bend the tube or just cut at 45deg angles and weld?
Vertigo wrote:3. space issues decree i will have to run the intake tubing in a vertical spiral to the carb mouth.
Vertigo wrote:4. im running a carb engine. is this even a good idea? ie. will i cause it to run badly/lean/not at all?
Vertigo wrote:5. anything else i should know? yes, i realise itll be somewhat hot, but that should be lessened by bypassing some of the air from the scoop around the box, as well as inside.
Vertigo wrote:hrm
if thats the case, whats the point in aftermarket air filters at all?
barryogen wrote:Vertigo wrote:3. space issues decree i will have to run the intake tubing in a vertical spiral to the carb mouth.
Bends kill a lot of the speed
bad20v wrote:P.S: Aftermarket filters are not 'wanky'If you knew anything about modifying an engine, you would know that they serve a valuable purpose and in the right setups can give good power increases over standard filters/airbox's.
rolla_fxgt wrote:Hey Barry how much did ridez charge u for you box?
