Lowered springs + superstrut?
Postby redline racer » Tue Nov 22, 2005 5:13 pm
Was wanting to lower my ae111 levin, will lowering it improve or hinder the super strut suspension? also will lowering cause any premature wear to the super strut?
any help appreciated, cheers.
(tried a search, but found no awnsers to these qs)
redline racer
Postby Low_Aa63 » Tue Nov 22, 2005 5:37 pm
sorry to jack the thread but what is super strut exactley?
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby Silent Knight » Tue Nov 22, 2005 5:40 pm
Low_Aa63 wrote:sorry to jack the thread but what is super strut exactley?
Search...
And redline racer yes you can lower a super strut. I think the problem with any car with stock struts though is that they wear out with lowering springs if the shocks aren't shortened. (I think this depends on how much you lower it.)
But no it shouldn't hinder your superstrut suspension if you properly lower it...
Silent Knight
Postby bad20v » Tue Nov 22, 2005 5:52 pm
Ummm.... good question, even though it has been covered before, and you have tried the search function.
The general school of thought is that it wont hurt the superstrut joints at all when you lower it as the geometry of the suspension arms are sufficent enough to allow for this. This doesn't mean that you can completely sack the car out and still be ok, but that a drop of around 50mm at most will be good so long as the vehicle gets a proper wheel align ment after installing the springs.
The other school of thought says that if you change your springs and lower your vehicle, the super strut joints will wear out quicker. But these people also don't realise that the quickest way to wear out any part of your suspension.... is to drive on NZ roads. :(
There are several different types of springs to use to lower your car, each has different characteristics and good points and bad points. Every person, especially on T.S, will give you a different opinion on each spring/ brand etc.
For your vehicle: (drop heights are only examples, each vehicle is different)
King Springs: 30mm or 50mm drop - most people say they give a poor ride quality
Dobisport: 30mm - Some people say they are a little too soft
Lovells: 25mm or 50mm - Not a bad spring, but sort of hard to come by.
Whiteline: 20mm or 40mm - Good ride quality, some springs are hard to come by.
TRD: 25mm - Good handling, available at a resonable price through Mr Revhead
There are others but these are the main brands. Its up to you which brand you go for.
Thank-You.
bad20v
Postby alamo » Tue Nov 22, 2005 7:45 pm
Whats about Jamex springs in a AE111 Superstrut? I'm thinking about getting some from trademe for my Levin...
http://www.trademe.co.nz/structure/0001 ... 182731.htm
alamo
Postby aesc » Tue Nov 22, 2005 10:29 pm
EX AE101 owner
2013 Ford Focus ST
aesc
Postby redline racer » Mon Nov 28, 2005 4:50 pm
Hey cheers for the info bad 20v. any other opions?
redline racer
