scope wrote:if springs are uncaptive so you go ahead and shorten struts, if you shorten them by too much does it lower the car as well? for example, springs are uncaptive by 20mm, if the struts are shortened by 25mm does the car go 5mm lower?
thanks in advance
gordon77 wrote:i am no suspention guru but i thought the springs determend the height, so it wouldnt lower your car![]()
correct me if im wrong...
scope wrote:gordon77 wrote:i am no suspention guru but i thought the springs determend the height, so it wouldnt lower your car![]()
but then i thought of it as this.. from 20mm down the springs couldn't force the strut up anymore as it will be maxed out therefore lowering the car more..? sorry if you don't understnad im' a bit intoxicated
vhpacer wrote:Sorry to go off topic but can a car with captive cut springs get a wof?
vhpacer wrote:O sweet. So just go to a wof station out of the city
l1ttle_d3vil wrote:and im guessing shortening the struts would lower the car. my springs are captive at the moment but I need to lower the car about 30mm more.
so if I shorten the struts by that much when I bolt it all back together the springs should get compressed by another 30mm right? I may be wrong but that was my understanding...
l1ttle_d3vil wrote:vhpacer wrote:Sorry to go off topic but can a car with captive cut springs get a wof?
as already said, it is illegal to have cut springs at all, but if they are captive most places won't tell the difference. you just have to make sure they still sit right in the top hat as that is moulded to suit the shape etc.
pervert wrote:vhpacer wrote:Sorry to go off topic but can a car with captive cut springs get a wof?
Not technically, it is illegal to have chopped springs full stop, but many garages will give a warrent to a car with captive cut springs, I get all mine fine and the backs have been chopped.
vhpacer wrote:How old was the cert though?
Users browsing this forum: Bing [Bot] and 16 guests
