Ako wrote:Are the brakes on your car the same as ST205 ones? I'd highly reccomend the EBC green or redstuff pads, depending on how you drive. Green are absolutely brilliant for road work, and are exceptional from cold - the red need a couple of stops to get the best out of them, but absolutely transform the braking of the car once they've been warmed up.
Give me a yell for pricing if you're keen...
fivebob wrote:Ako wrote:Are the brakes on your car the same as ST205 ones?
Fronts are the same shape as SW20 pads. Rears are different and not a shape I've seen before. They are also small and, along with the thin disk which doesn't dissipate the heat well, are IMO a large part of the problem
mine are generally shitty, i need decent padsXERO wrote:When the breaks are working good, they work very good!!!
Has anyone ever done a proper 100-0 test to see how far it takes to stop??
Santa'sBoostinSleigh wrote:good to see its just not me then!
