Have just had my rebuilt engine fitted and it threw up fault codes 51 and 52. 51 has been rectified but 52 is knock sensor/air con/ECU. The air con has been disconnected with just the pump in place as it is needed to retain the power steering. Is it possible that the disconnected pump is causing this problem, the revs sit at 1,500 at idle as well as if the engine were trying to compensate for a/c being on or something. Other than that the engine runs very well.
Any ideas? And is the knock sensor on the rear of the block between 2 and 3?
