Filter for 4AGE
Filter for 4AGE
Postby SpeedRacer » Tue Nov 29, 2005 10:52 am
I plan to stick a pod filter on my 4AGE red top. Here are the problems Ive been thinking about and would like to be re assured on.
* Its MAP sensored(?) will a pod filter cause problems with that?
*Theres a little sensor thing that goes into the filter air box. Where should I mount that on the pod filter?
*Also can I still use the plastic pipe it comes with or should I get a metal one? (curious as to whether the pipe will change shape due to air pressure) Also where do I get one of these from?
Sinister Sleeper 35
SpeedRacer
Postby Santa'sBoostinSleigh » Tue Nov 29, 2005 10:56 am
1) no
2) drill a hole in the intake pipe and stick it in there (read: silicon or gromet)
3) get a nice shiny bling piece of stainless (i might be able to source you one - just let me know dimensions)
4) build a cold air box so you dont suck in hot air
OR: just save all the hassles and get a decent panel filter
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Mr Revhead » Tue Nov 29, 2005 11:46 am
yeah a good panel filter with a duct into the air box can work very well.
the biggest thing is make sure your sucking cool air
TRD do a good pod filter :P
Postby matt dunn » Wed Nov 30, 2005 5:38 pm
I have a K&N Panel filter to fit a Redtop smallport AE92,
done less than 1000 k's in it's life, still in it's box.
Let me know if you are keen via PM.
