ae92 fuse box
ae92 fuse box
Postby deaf_rattle » Wed Nov 30, 2005 6:47 pm
can anyone tell me what the fuse box that is directly connected to the positive terminal on the ae92 big port 4age does?
trying to sort out the wiring for the tinny valve.
Postby gordon77 » Wed Nov 30, 2005 7:03 pm
they are the main fusable links, designed to melt in the event of a seriious wiring fault. they protect the wiring loom from damage :)
thank you mr Haynes :P
What is RR?
gordon77
Postby deaf_rattle » Wed Nov 30, 2005 10:48 pm
cheers.
so i dont need to wrry about them when i put the new loom in? or will i need to run those still?
Postby Alex B » Wed Nov 30, 2005 10:58 pm
Its a safety thing, as in to stop the car bursting into flames in a serious wireing fault, piss easy to put back in place any way.
Postby deaf_rattle » Wed Nov 30, 2005 11:00 pm
isnt it part of the ae92 4age loom tho?
so would it need to be wired into the 20v loom when i do the conversion?
Postby Alex B » Wed Nov 30, 2005 11:01 pm
Its just a set of 2 or 3 fuses if i remember correctily, if you remove the cover on the back of the box it should reveal some bolts you can undo to take it out of the wireling loom.
Postby gordon77 » Wed Nov 30, 2005 11:53 pm
pyro_sniper2002 wrote:Its just a set of 2 or 3 fuses if i remember correctily, if you remove the cover on the back of the box it should reveal some bolts you can undo to take it out of the wireling loom.
that is exactly right :)
What is RR?
gordon77
