ae82 20v Conversion - Problems
Postby XS1V » Thu Dec 01, 2005 5:30 pm
Hey all i just started the 20v in my ae82 fxgt for the first time :D
Problem is though, it wont keep running :cry: it starts then dies, it just wont idle. It will keep running though if you give it continuous bursts of throttle, but not constant throttle or it dies also. The problem im guessing has to be electrical as i havnt touched anything to do with the engine since removing it from my ae101 levin where it was running sweet.
Anyone have any ideas?? Thanks in advance :)
ST205 Group A Rallye #2363
XS1V
Postby EVL20V » Thu Dec 01, 2005 5:56 pm
vacuum leak somewhere?
EVL20V
Postby matt dunn » Thu Dec 01, 2005 6:22 pm
lack of fuel pressure.
There was a thread that had this exact problem quite a while ago.
Postby Mr Revhead » Thu Dec 01, 2005 6:23 pm
checked ya AFM plug?
and theres another common thing that escapes me now....
ill be back......
Postby deaf_rattle » Thu Dec 01, 2005 6:26 pm
hey
i would be keen to have a look at your wiring sometime.
would that be sweet?
Postby 13 » Thu Dec 01, 2005 7:16 pm
check if ur idle speed control valve has been pluged in power....
13
Postby 85AW20v » Thu Dec 01, 2005 8:47 pm
There's an earth wire on the AFM plug that needs to be connected to....... an earth!! White with a black trace. Had the same problem with the transplant into the AW.
See ya
Simon
85 MR2 20v
85AW20v
Postby KinLoud » Thu Dec 01, 2005 10:39 pm
Put a jumper wire from the FP to the B+ in the diagnostic plug.
This bypasses the fuel pump relay. If you engine runs normally then you will have to sort out a wire from the AFM switch to the fuel pump relay.
In MAP sensored motors the computer controls the fuel pump relay after you let go of the starter key. In 20v silvertops the pumps is controlled by a switch in the AFM which closes when you have air flowing through it keeping the flap open. In both cases MAP and AFM the fuel pump will stop when the engine stops so there will be less fuel spraying around if you have an accident.
Ken
Ham
021 408 863
Postby sergei » Thu Dec 01, 2005 11:46 pm
as pple said, fuel pump relay not connected thru AFM, had to sort it out when I did wiring for a 20v conversion on a 4AFE...
Postby XS1V » Fri Dec 02, 2005 12:27 pm
EVL20V wrote:vacuum leak somewhere?
All lines havnt been touched but have rechecked and all looks good
matt dunn wrote:lack of fuel pressure.
Fuel pressure seems to be fine, has the 20v pump running and yea :?
Mr Revhead wrote:checked ya AFM plug?
ill be back.......
Will do that, its all plugged in, maybe some wires need to be connected somewhere.... Hope your back soon :D
deaf_rattle wrote:i would be keen to have a look at your wiring sometime.
Yea that would be awesome, im home again on sunday avo, stupid broken ankle makes getting around tough :evil:
13 wrote:check if ur idle speed control valve has been pluged in power....
where is that??
Simon85MR220v wrote:There's an earth wire on the AFM plug that needs to be connected to....... an earth!! White with a black trace. Had the same problem with the transplant into the AW.
where through the 20v loom does it run?
KinLoud wrote:Put a jumper wire from the FP to the B+ in the diagnostic plug.
Ok have done that just now and didnt make a diff :cry:
sergei wrote:as pple said, fuel pump relay not connected thru AFM, had to sort it out when I did wiring for a 20v conversion on a 4AFE....
Yea dont think its that after testing it
XS1V
Postby MetalupYoAss » Fri Dec 02, 2005 8:45 pm
try idle bypass valve, when i did my conversion, i had similar problems, you need to find the tube coming off the idle bypass valve (perhaps some nice toyspeeder can show one on a silvertop photo) and plug the pipe up, see if this helps.
MetalupYoAss
Postby 85AW20v » Mon Dec 05, 2005 7:27 am
Sorry - can't remember where the wire pops out - could be on a grey plug somewhere near the diagnostic plug area as thats where I've connected mine. Use a meter to trace it. I've pulled out all the stuff I don't need out of my loom so don't have the extra plugs etc.
To test if its the AFM earth, turn the key on then hold open the AFM flap. The fuel pump should run all the time until you close the flap. To see if it only runs while cranking, pull the solenoid wire off the started motor and then turn the key to the start position - just so you can hear whats happening with the fuel pump. Again the fuel pump should run until you let the key go. Normally, the AFM side of things takes over once the flap is open from air flow into the motor.
Hope this helps.
See ya
Simon
85 MR2 20v
85AW20v
Postby XS1V » Wed Dec 07, 2005 5:49 pm
Ok so ive traced it pretty much top the AFM i think.... it will run if you hold the flap open a little with your hand, so what could that be?
All three earths are definately going to appropriate earthing points. The three yellow wires to ecu give both 12v and ground on the multimeter though, dont know if they are supposed to do that or not :?
Any more ideas?? Everyones help is appreciated :)
XS1V
Postby matt dunn » Wed Dec 07, 2005 11:50 pm
XS1V wrote:Ok so ive traced it pretty much top the AFM i think.... it will run if you hold the flap open a little with your hand, so what could that be?
When the engine is running the airflow should hold the flap open.
If it does not then the must be an airleak between the AFM and the throttlebody?
BOV possibly?
Postby sergei » Thu Dec 08, 2005 12:40 am
defently a leak somewhere.
Postby XS1V » Thu Dec 08, 2005 5:39 pm
Well i have sorted that problem :) I had changed my airbox cover because my old one was dented but the new one hadnt been sealing so ive swapped them back and yea :D
Just got to work out getting the back up light switch going and the front park lights
XS1V
Postby deaf_rattle » Thu Dec 08, 2005 6:23 pm
hey
You going to be home this weekend?
if so would it be sweet to pop round?
Postby XS1V » Fri Dec 09, 2005 12:20 am
deaf_rattle wrote:hey
Yea i will be home sunday afternoon, flick me a text on 0276642757 when you want to come round :)
XS1V
Postby XS1V » Fri Dec 09, 2005 12:55 pm
Well just wired up the reverse lights so thats all sweet and also got the park lights all done as well :)
XS1V
