Sparkplug leads ....which ones ??
Postby BzzzzR » Fri Dec 02, 2005 2:33 pm
Hi guys ... just a quick question on sparkplug leads ... did a search didnt help to much .. Im getting a service done next week and will be putting new irudium sparks in it and thought i might as well do the leads ....so whats the deal iv heard of good gains being made with the step up to 8mm leads... is this true ???can you go too big??? what brand of leads do ya recken??
Any help will be much appreciated 8)
BzzzzR
BzzzzzzzzR
BzzzzR
Postby Al » Fri Dec 02, 2005 4:56 pm
Stock Toyota leads from Mr Revhead.
They seem to be sufficient for 500+rwhp turbo mr2s.
Al
Postby AJz » Fri Dec 02, 2005 6:03 pm
if you dont mind spending the $$$ on buying iridiums (cos they aint cheap) then why not go all out and get either sum champion TRD or Top Gun leads. If the car is still using factory parts, might pay to do a new dizzy cap and rotor while your at it, then you wont need to worry bout the ignition side of things.
I had vtax :(
AJz
Postby Dell'Orto » Fri Dec 02, 2005 6:10 pm
You'll find most bigger leads dont have any larger core than stock ones, just thicker shielding. I have 10.5mm Eagle leads on the 2, and the core isnt much if any thicker than 7mm Champion ones.
Iridiums are a waste of time IMO, unless the plugs a bitch to get at.
Postby Mr Revhead » Fri Dec 02, 2005 6:59 pm
yeah stock leads and platinum plugs are usually all you need.
