st205 dyno'd - feed back please
Postby TRDmod » Mon Dec 05, 2005 11:56 pm
hi, got my st205 dynod recently, this sat in fact, and after all the mods i spent on it.
original stock only with a 2.5 inch ex and cold air, 12 psi was 163.9 kw
now with the new set up 12 psi was 173.1 kw atw, and 15.8 psi was 206kw atw
is this normal?
Domino's Pizza.....
TRDmod
Postby Malcolm » Mon Dec 05, 2005 11:58 pm
you might have to go into a little more detail for those of us not familar with your set up
206kW is pretty decent in a 4wd, should make it a low-mid 12 sec car I would imagine.
Postby fivebob » Tue Dec 06, 2005 12:01 am
This thread is useless without dyno plots (and a complete list of mods). :roll:
Postby Akane » Tue Dec 06, 2005 3:38 am
fivebob wrote:This thread is useless without dyno plots (and a complete list of mods). :roll:
Postby GT4 20 » Tue Dec 06, 2005 7:52 am
As a comparison...
2.5" full exhaust system with decat.
TOMs panel filter
Profec B Spec II EBC set at 16.2psi.
Would certainly be interesting to see your dyno printout and what mods you have done to acheive 206kW @ wheels.
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Dell'Orto » Tue Dec 06, 2005 12:32 pm
Christ, what setup is LIVNOW running?? Nearly 26psi peak boost pressure 8O
sh*t sorry
Postby TRDmod » Tue Dec 06, 2005 3:45 pm
sorry guys Sh*t for got to put mods
custom equal length manifold, machined inside to smooth it, kinda novelty lol turbonetics 450 bhp rated turbo with 3.5 inch inlet designed for top end power. codl intake, 2.5 ex no cat, custom 3 inch down pipe from turbo, 35 mm ex wastegate, no screamer pipe. greddy profec type s boost controller.
not to mention a recaro seat that should add 50 bhp:D so all of the above
206 on 15.8
gt4 20, what high kw rating di dyou achieve? it doesnt say on ur printout
what quarter mile?
Domino's Pizza.....
TRDmod
sorry
Postby TRDmod » Tue Dec 06, 2005 3:47 pm
sorry green line though was gt4 20 as well, disregard that gt420 that last bit on the last thread:D
torque performance said not to touch the boost anymore, that its fine where it is
Domino's Pizza.....
TRDmod
Postby GT4 20 » Tue Dec 06, 2005 7:06 pm
So where is the dyno printout?
Gary
GT4 20
Postby Akane » Tue Dec 06, 2005 8:55 pm
I just noticed that Gary's and kiwimr2's dyno are all done in 3rd gear, while mine is done in 4th.
Anyone know how this will affect the results?
hi
Postby TRDmod » Tue Dec 06, 2005 10:47 pm
i dont know how to put the printout on, and also i dont know how to scan it with out a scanner
but its done in third gear, so its the same as yours looks similar but 206 and the torque is a lil higher
as far as i understood, one of ther easons doing it in 3rd or 4th gear is so they can read the power out put slowly....on 1st gear the dyno wouldnt be fast enough to take in the info...is this right, thats what iw as told by some...none the less mines in 3rd gear.
sorry cant put the printout on, why do you want it?
you dont believe me:P well, if you dont thats ok, i didnt believe it either, i even asked him if it was right....and i dotn think its that high..well i dunno, definately happy with how much faster it is though:D oh yeah!
Domino's Pizza.....
TRDmod
Postby Malcolm » Tue Dec 06, 2005 11:17 pm
Akane wrote:I just noticed that Gary's and kiwimr2's dyno are all done in 3rd gear, while mine is done in 4th.
well power doesn't change with gear ratios, but torque does, so your torque at the wheels will be lower, but other than that it shouldn't make much difference
Postby Drifter4ag » Tue Dec 06, 2005 11:35 pm
our dynos always read slightly lower power readings in 3rd gear over 4th as we have more drivetrain loss in 3rd than 4th .. but there is really stuff all in it ...
whats that plot with nearly 250kw ?
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby Malcolm » Tue Dec 06, 2005 11:50 pm
well a turbo car will have more load and should come on boost sooner in higher gears, doesn't seem to make sense that the gear should change drivetrain loss
Postby GT4 20 » Wed Dec 07, 2005 8:31 am
Drifter4ag wrote:whats that plot with nearly 250kw ?
Try reading the dyno plot properly. The answer is there :wink:
Gary
GT4 20
Postby GT4 20 » Mon Dec 12, 2005 3:30 pm
Still waiting for this dyno chart :wink:
Gary
GT4 20
dont have scanner
Postby TRDmod » Mon Dec 12, 2005 3:45 pm
dont have scanner
Domino's Pizza.....
TRDmod
Re: dont have scanner
Postby Santa'sBoostinSleigh » Mon Dec 12, 2005 5:21 pm
TRDmod wrote:dont have scanner
dont have dyno chart dont you mean....
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Dell'Orto » Mon Dec 12, 2005 5:39 pm
Thats a bit harsh, not everyone is mad 1337 and has all the computer bits. Still, a pxt will be fine ;) :lol:
Postby GT4 20 » Mon Dec 12, 2005 5:48 pm
Are you telling us that you don't know anyone with a scanner 8O
Or is Santa right :wink:
Gary
GT4 20
