what the fallah? 3tgeu....
Postby Low_Aa63 » Tue Dec 06, 2005 6:48 pm
check out this starlet
http://www.trademe.co.nz/Trade-Me-Motor ... 121107.htm
Ok so its got a turbo head and block but why is it running 4 leads?
Some one care to ask...
Would be good if you put a turbo on it, assuming hes knocked up the compresion.....
High compresion boost is where its at!
The list so far
Te71, Ae82, Ke70x2, Mx73x2, Ga61, Gx61, Ra63, Aa63, Ae70, Ae85, Ke25, Ke30, Ke36, Gz10x2, Hb11, Ta40, Ma45......
geishaboy wrote:I want a number plate with "geisha" on it
But I should probably get a car first
Low_Aa63
Postby YeMs » Tue Dec 06, 2005 10:05 pm
thats skandelous. AFAIK the 3TGEU only came single spark, it looks like a 3tgteu with out the turbo. it is actually an abortion. if u wanted single spark, should go with a 2t head.
Your local Hybrid Elite tech
YeMs
Postby wde_bdy » Tue Dec 06, 2005 10:20 pm
YeMs wrote:thats skandelous. AFAIK the 3TGEU only came single spark, it looks like a 3tgteu with out the turbo. it is actually an abortion. if u wanted single spark, should go with a 2t head.
There is no 3TGEU.
There is a -
3T-EU (single cam injected, not OHC)
3T-GTEU (twin cam injected turbo)
2T-GEU (twin cam injected)
Probably running on a 2T-GEU computer and coil setup so took off the redundant leads.
Callum
wde_bdy
