My CT20 off my 3tgte is poked,heaps of radial play in the bearings/shaft + leaking oil seals,this is the first time iv taken one apart and need a little help from all u experts out there,the pics below show how far iv got,so.....how do i split the center bearing section from the turbine valute/housing,ive removed the compressor wheel but not the turbine wheel(i dont have to do i?) + removed the internal circlip behind the turbine wheel but she wont part,wats the secret?
So i don't need to take off anything else,the center bearing section just spigots into the turbine housing and with a quick once over with the oxy acetylene and a tap she'l come free??
yep
just dont qench it or it will crackoh and be carful with the tapping
it wont take much to kill the turbine wheel in the ways of clipping it on the way out
Cheers for that vvega,and yems,the turbo's of one of my 3 (brag brag brag ) spare blocks,just pulling a couple down 2 see if ive got enough good parts to make a complete one,chur chur tho
