fangsport wrote:i used a combination of Monroe and H/Duty Dobinsons in the Commonwhoe wagon and they were good for 7-10,000km, and now it's back to being an ill-mannered sloppy pile of poo.
wouldn't use or recommend either products again
bad20v wrote:
For your commodore, Fangsport, I would go with the Whiteline springs... not the 'raised' ones though!![]()
thanks for the tip, what do you recommend for rear bushes? i have already done the front sway bar conversion/modification.
FYI it's a towing barge/workhorse and very rarely seen with a usable rear seat.
bad20v wrote:It really depends on what you want to achieve by replacing the rear shocks:
* Stiffen up the rear end for better handling?
* Stiffen it up for better load carrying ability (seeing that it a wagon)?
* Your existing ones are stuffed and you just want to get new shocks?
If you could give a bit more info about your reasons for changing just your rear shocks and not the fronts as well, and maybe the springs, I could give you a more specific answer.
bad20v wrote:We'll seeing as you are on a budget, I would recommend going for the KYB's as they are a good shock at a reasonable price range.
Personally if it's a poor handling problem, I would look into getting the whole suspension sorted not just the rear shocks. You maybe getting poor handling from worn suspension bushes as well as worn rear shocks. What you may think is one thing, maybe another. I would proberly recommend checking your car into a suspension shop for a good looking over and assessment. It shouldn't cost you anything, and just get them to give you their opinion on what needs to be done. But go to a reputable shop not some backyard cowboy.
An example of this was a customer I had that came in to get 2 new front shocks, as his WOF guy said they were stuffed as they were creaking. He was prepared to fork over $400 to get these replaced, but only ended up paying $25. Why because when I got his car up on the hoist, the shocks were fine, it was just a worn sway bar link making the noise. I replaced it and sent him on his way with a smile on his face and a few nice words for the WOF guy.![]()
Good luck.
Santa'sBoostinSleigh wrote:better make some suggestions for my racecar then
Users browsing this forum: Google [Bot] and 23 guests
