Hey,
I just bought a toyota corolla liftback with 4A engine.
It has a pretty bad hesitation/miss between 2000-3500rpm, what should i start checking/replacing?
first thought was plugs?
Thanks
James
BZG Wagon wrote:Try spraying CRC Clean-a-Carb into the Throttle Body. Open the butterfly right up and spray some in, possibly clean parts of the throttle body out with a rag. Then start the car up (it may not start first time; but it will start) and spray some in whilst the car is running. Then connect up the air intake system back up.
I find this usually make a huge difference.
Jebus wrote:Yep take all the air filter assembly off, spray it all round the carb and rev it a bit when you spray it, itll blow white sh*t out of the exhaust, just wait till it burns it all away.
But first id change ya plugs etc first.
Volatile wrote:Jebus wrote:Yep take all the air filter assembly off, spray it all round the carb and rev it a bit when you spray it, itll blow white sh*t out of the exhaust, just wait till it burns it all away.
Cheers,
I've pulled the plugs out they seem all good. Is there anyway of testing leads?
I'm convinced it's fuel related as it only miss's just after 2500rpm and then pulls as normal after 3500rpm
