tomo1985 wrote:What weight would you suggest would be the maxium to tow on a BZ-T Carib 6 speed black top?
Where would you suggest in CHCH to get one made custom around my exhaust.
What is the cheapest way of stoping guard rub?? I have 18inch wheels lowered guards rolled would putting in bigger bump stops be ok?
Chickenman wrote:The 6 speed is a closer ratio box so at 100km's in 6th you're doing about the same revs as a 5 speed(doing 100kph in 5th).
But as second has no meaning until 100 kph (when pushing it) the 6 speed is a waste IMHO.
inside the trailer.
BZG Wagon wrote:Chickenman wrote:The 6 speed is a closer ratio box so at 100km's in 6th you're doing about the same revs as a 5 speed(doing 100kph in 5th).
inside the trailer.
Interesting... So any benefit you would recieve from a 6-speed would probably be lost through an extra gear change?
My 5 Speed BZ-Touring hits exactly 100kph in Second @ Redline; can someone with a six speed tell me where their second gear ends?
TrouserFxGt wrote:I tow all the time with my 5 spd bz-t.
Three days ago I towed a large trailer with 439kg on it. No problems at all. Up and down hills just fine.
About two months ago I towed with about 8-900 kg on and that was a bit of a struggle but did it fine none the less and with a car load of people. You just have to hold each gear longer than normal. I was changing at 5k.
Users browsing this forum: Bing [Bot] and 8 guests
