Help Pls! New Cams for My AE111
Postby muff|n » Thu Dec 15, 2005 12:16 pm
I have a 20v Blacktop and...
I'm looking at getting new cams, and am wanting to know..
What brands do you reccomend?
Who do you reccomend to install/talk to about it?
Or even, being the newb I am, would I be able to do it with a few instructions?
And also, I hear talk of adjustable cam gears.. Would they be of great benifit? (I don't know how they work :oops: )
Assuming money is no problemo...
And if I replace the larger of my cams, can I use the old big ones for my smaller ones? Or do I need to replace the smaller ones too?
Or should I just leave it alone..
Reason I ask is I want the performance increase at both ends of the rev scale.
I'm aware that it will idle like a bitch.
And I'll be getting a GReddy E-Manage before, so it will be all ready for camys.
Any help is MUCH appreciated.
Thanks in advance :D
muff|n
Postby Dell'Orto » Thu Dec 15, 2005 1:01 pm
Seeing as you're in Christchurch, go talk to Kelford cams, they'll be able to tell you exactly what will work and what gains you're likely to see.
I dont get what you mean by replacing your bigger cams, you only have 2 cams in your engine - inlet and exhaust. If what I suspect you're thinking is VVT has 2 cams for each side, it doesnt work like the VTEC system.
If you want to keep VVT, you wont be able to use adjustable cam gears (unless someone has made an adjustable VVT pulley somehow)
Unfortunately going for a angrier spec'c cam is a bit of a trade off, if you want high RPM power you're going to have to sacrifice some low end torque...
I'm not sure how effective those Greddy E-manage ECU's are, but if you're looking to get serious with your car, a decent ECU is a must.
Postby CozmoNz » Thu Dec 15, 2005 1:12 pm
Money no object eh?
http://www.todaracing.com/products/toyo ... specs.html
Pick what you want / need (go have a search on cams for 4age, if its not covered on ts, it will be somewhere else online).
Outline what you want from your engine before choosing cams, youll cut your legs off if you choose the wrong ones X_X. oh and as covered above, you cant have both high end and low end ;). (well sort of, thats why toda make vvt useable cams)
http://www.todaracing.com/products/toyo ... train.html
Id get those just for the "safety" that you know your using new stuff up there, and its toda even! more bling! haha.
http://www.todaracing.com/products/toyo ... ulley.html
Finally if you want some adjustable cam gears, there ya go! I think Jimtune can also make some for 20v's btw. Toda is $300+ USD and then youll have shiping and junk.
then of course, and just because you should:
http://www.motec.com.au/ems.htm
:) Have a nice day.
Rayne For President!
CozmoNz
Postby muff|n » Thu Dec 15, 2005 1:53 pm
Wow thanks fellas!! That's so helpful!
You rock :)
I'll let you know how I get on and what I do :D
Cheers again!
muff|n
Postby muff|n » Thu Dec 15, 2005 1:55 pm
Mmm, Boost wrote:I dont get what you mean by replacing your bigger cams, you only have 2 cams in your engine - inlet and exhaust. If what I suspect you're thinking is VVT has 2 cams for each side, it doesnt work like the VTEC system.
Yea my bad, thought it was the same. :oops:
muff|n
cams
Postby Celica RA45 » Thu Dec 15, 2005 6:40 pm
there is a cam that we use for the black top 20 v it has 9.7mm lift and is a billet cam but they come from aussie and you can use the std ecu and you still use the vvti and its about 30degress more at 50thou agianst the std black top cam
Celica RA45
Re: cams
Postby 92GTApex » Thu Dec 15, 2005 9:41 pm
Celica RA45 wrote:there is a cam that we use for the black top 20 v it has 9.7mm lift and is a billet cam but they come from aussie and you can use the std ecu and you still use the vvti and its about 30degress more at 50thou agianst the std black top cam
how does it run?
and what sort of power figures?
dyno sheets?
Logan
Current ride: 92 Levin GT Apex
Current project: 91 Levin GT Apex (Crashed - It wasnt me)
www.area-51.co.nz
www.toyperformance.org.nz
www.lextreme.com
http://toyspeed.blakjak.net/profiles/pr ... hp?id=1731
92GTApex
Postby RedMist » Thu Dec 15, 2005 10:32 pm
You seriously want to be looking at Toda at the moment. The prices through the site listed in the parts for sale section are fantastic. It may cost you slightly less for Kelford however they arent named Kelford mystery sticks for nothing.
Adjustable cam gears allow you to dial in the cams to get the most power from them. Its pretty pointless getting good duration aftermarket cams without adjustable cam gears. Another option for cam gears are the ones made on trademe or sold through Palmside.
The answer is Helmholtz!
Toyota ST185 Celica Rally.
Toyota ST205 Celica Rally.
RedMist
billet cam
Postby Celica RA45 » Thu Dec 15, 2005 11:11 pm
they cost about 400 odd aussie and you have to set up the cam and it makes about 5kws more than std cam
also you have to set it up at 210 lifter rise at tdc and thats in its advanced state then you retard it ,my mate has 1 in his ke25 rolla ,it kicks arse for what it is
Celica RA45
Postby 92GTApex » Fri Dec 16, 2005 9:47 am
5kw for that much extra duration and lift?
Logan
www.area-51.co.nz
www.lextreme.com
92GTApex
Postby Fraud » Fri Dec 16, 2005 9:58 am
P.S.
Good time to buy from overseas..... Exchange rates = ace!
:lol:
Fraud
