Ae92typeX wrote:I know you say the belt is fine, but have you rechecked the tension after runnung it for a week when it was new. its not uncommon a belt need retensioning
I would say without dout that belt slipping is your problem, there is very few reasons why the supercharger would be making whining/screeching noises, if it had no oil the noise would be heard all the time, however it could be you supercharger clutch slipping, but its not that common. How do you know that the noise is coming from the supercharger?? it could be from other belts which are slack.
