Need to check how much my ute has been lowered so I can get another set of springs reset, moron "professional" springmaker who did the set in it when I bought it put a curve in them behind the diff which $$% the pinion angle and gets too close to the fuel filler neck.
Current specs (centre of wheel to lip of wheel arch)
Front - 32cm
Rear - 30cm
Front is on Kings Lows but heavier motor than most KE70's so likely to be a fair bit lower (18R-GE). Could other please post their standard measurements or lowered measurements with details of how much the leaves were reset.
Callum
