T3/4 spool time?
T3/4 spool time?
Postby Crucible » Tue Dec 20, 2005 8:47 pm
Ok, Im gonna turbo my GTZ and have sorta decided to use a T3/4.
Ive still got a bit of homework to do but from what Ive read they are a good choice for topend power which is what Im after :lol:
I was just wondering if any of you gte boys using this turbo can tell me what sort of RPM ill see full boost at? How laggy are they? Also any pointers on these puppys or any negatives?
It will be on an ActionDan Manifold
cheers heaps in adv :lol:
TNT
Crucible
Real Life Mechanic
Postby Malcolm » Tue Dec 20, 2005 8:50 pm
t3/t4? maybe you'd like to be a bit more vague? like perhaps just asking how turbos in general spool?
Postby vvega » Tue Dec 20, 2005 9:06 pm
with a .48hot .50 cold expect it to spool around 3-4 k
v
vvega
Postby Skidman » Tue Dec 20, 2005 9:14 pm
Depends on a few variables aye. Hard to say with the given info.
Intake mods? after market comp? Custom Exhaust manifold? Standard cams?
If you get a real after market computer you would get away with minimal lag-and use shite loads of gas. :twisted:
Hondas are made for people who dont know better.
Skidman
Postby vvega » Tue Dec 20, 2005 9:23 pm
my example would be if you used a standerd motor and ecu or aftermarkt without antilag
v
vvega
Postby Skidman » Tue Dec 20, 2005 9:41 pm
Yea I agree, posibly 4-5k, cause its a resonable size turbo for a 1600cc. Youd probly run out of RPM beore Puff I would imagine. Most of the T3/T4 we see in our shop are upgraded turbos on standard engine 2L 4 cylinder cars.
Skidman
Postby vvega » Tue Dec 20, 2005 9:52 pm
my data comes from doing it :D
and knowing many poeple that have also done it :D
im not a talker im a dooer
v
vvega
Postby Skidman » Tue Dec 20, 2005 10:07 pm
:oops:
Skidman
Postby vvega » Tue Dec 20, 2005 10:09 pm
click on the 1uzaw11 at the bottom of my post to see my latest project :D
v
vvega
Postby Skidman » Tue Dec 20, 2005 10:26 pm
Holy shit!! might talk to you about that tomorow :wink:
Skidman
Postby bluemaumau » Tue Dec 20, 2005 10:28 pm
my m8s got a T3 on his b16a turbo with pod and 2.25exhaust spools at 2250-2500rpm! full boost(5.8psi) before or just after 3000rpm. and hes got a external.
Postby evil_si » Tue Dec 20, 2005 10:29 pm
mazda ht18 core, and skyline t3 exhaust housing, standard gtz boost from 3300.
t3/t4, .50 comp. .63 exhaust, boost from 4000.
evil_si
Postby Dell'Orto » Tue Dec 20, 2005 10:29 pm
Not surprising it spools like that with a 2 1/4 exhaust, would be quite the punchy little thing.
Postby evil_si » Tue Dec 20, 2005 10:39 pm
bluemaumau wrote:my m8s got a T3 on his b16a turbo with pod and 2.25exhaust spools at 2250-2500rpm! full boost(5.8psi) before or just after 3000rpm. and hes got a external.
from my experience, vtec turbos are completely different to a 4age on boost, with response, lag, power
evil_si
Postby Bazda » Tue Dec 20, 2005 11:07 pm
I used a 0.5a/r front cover with a 82.5mm comp wheel and a 0.7a/r twin divided exhaust with a 72m wheel.
Ran the standard ecu with 0deg initial timing and full bosot at 4800 :P
If i ran the timing normal full boost was by 4500 but standard ecu made the timing go too high at teh higher rpm.
Seems laggy but did it have some go up high :twisted:
Postby Drifter4ag » Tue Dec 20, 2005 11:48 pm
my ht18 gets to 15psi at 3600 rpm ... .. 5.1psi is there at like 1500rpm on mine .. and it it was higher comp it would be tehre at like idle
Garage |-" '|
Current Rides
Vitz RS :D
Previous,
JZX91 MARK II CHASER
Drifter4ag
Postby Crucible » Wed Dec 21, 2005 12:47 pm
All_Fours wrote:t3/t4? maybe you'd like to be a bit more vague? like perhaps just asking how turbos in general spool?
Sorry that was vague, what was I thinking? 8O .......Its late Hi comp GZE, using a 4>1 Custom Ex Manifold - Im going to ask Action dan to Fabricate one for me. Apart from the N/A inlet mani the Cams, E.C.U and everything else will be standard for now until i can get dollars together for after market ecu etc.
I know this is a thrashed topic but was just wanting to know overall if a T3 is too laggy or not, I understand alot comes into the Lag factor etc. I was going to go down the TDO4 road but have read that they lack Topend and run out of huff. So now im back to the drawing board on Turbo choice as I want a good topend Combo
When people say they are using a T3/4 are they referring to a unit that shares differant housings as in a hybrid like T3 Exhaust housing with a T4 Compressor housing??? or does T3 and T4 share the same flange so they word it T3/4???
Sorry to sound like a Dunbass but any help would be much appreciated, thanks for the advice so far Guys :lol: :lol: :lol:
TNT
Crucible
Real Life Mechanic
Postby Ako » Wed Dec 21, 2005 1:23 pm
No, the vague bit is the "T3" bit. There's literally hundreds of different sizes!
TD04 on a 1600 4AGE.. I can't imagine it running out of puff. If anything its probably perfect. Put it this way - anything meant as factory fitment on an 1800 engine would be just right for making power on a 1600, anything sized for a 2L (td05 - 14b for example) would work if you can be arsed waiting til 5Krpm ish I guess. My city turbo didnt get any useful boost till 4500rpm, then it hit well enough you'd change lanes accidentally and light up in 3rd. Why people persevere with peaky FWD turbos totally baffles me.
Ako
Postby Silent Knight » Wed Dec 21, 2005 1:31 pm
True-No-Turbo wrote:or does T3 and T4 share the same flange so they word it T3/4???
No...T3/4 is the flange.
With that you can have hundreds of different combination of turbos to slap on...
Silent Knight
Postby Malcolm » Wed Dec 21, 2005 1:43 pm
you sure? I thought t3/t4 meant t3 turbine side and t4 compressor side, meaning you'd have a t3 exhaust flange
