All_Fours wrote:I reckon you should make a fibreglass replacement panel
you could even make it removable so you could have all the weight savings of not having the sunroof, but the wicked-ness of an open roof in summer
Mr Revhead wrote:i think you will find there are rules for doing that for a race car.....
its been a while but i recall having this discussion before and its not as easy as just filling the hole....
check with MSNZ (or leon) doesnt cost to ask, but can cost to fix a f**k up
Santa'sBoostinSleigh wrote:so you rekon just cut all the roof crap out, apply heaps of sealer and heaps of pop rivets?>
Santa'sBoostinSleigh wrote: or use an ali panel
including an arse load of sealer and 100's and 100's of rivets!
flygt4 wrote:ive seen sumthing on tv once where they attempted to weld a roofwas a very bad idea , they heated it too much and it buckled and flexed uber bad.
All_Fours wrote:welding it in will almost certainly cause the roof to buckle
I briefly owned a *shudder* ma61 race car (i only bought it for parts, promise), and it had a steel panel rivetted in place of the sunroof
anyway if it's for a racecar, I'd just go fibreglass or steel, but don't weld it in, just fix it with fibreglass
