Questions on 1983 Corona
Postby Glancn » Thu Dec 22, 2005 1:28 pm
Hi all, have recently bought an 83 Corona (rwd, 3T) and have a few Q's about these cars :)
*What series/model diff do they have and what upgrade options are there i.e. AE85/86?
*What ratio does the diff run?
*What is the model number of the car i.e. KE70, AE...?
and just unrelated, how hard will it be to fit a set of front seats out of an AE82 FXGT?
Cheers :D
Glancn
Re: Questions on 1983 Corona
Postby fangsport » Thu Dec 22, 2005 2:17 pm
Glancn wrote:Hi all, have recently bought an 83 Corona (rwd, 3T) and have a few Q's about these cars :)
Cheers :D
* most run the 6.7" T series diff, same as TE71/AE86. if it is 10 bolt then it should be .
* crappy usually 3.7,3.9,4.1
*should be a TT132/141 depending on body shape.
the ID tag is on the firewall above engine, if it an import, the diff code will be listed on it
fangsport
Postby Glancn » Thu Dec 22, 2005 2:28 pm
Thanks for that. Its a station wagon. Just thinking of improving the rear suspension sometime down the line as its using a leaf setup at the mo.
Glancn
Users browsing this forum: Bing [Bot], Google [Bot] and 5 guests
