1994 Hilux, engine conversions?
Postby Scheme » Thu Dec 22, 2005 9:14 pm
Hey guys,
Mates got a hliux 2.4 diesel, 2l motor, lsd etc.
What are the easier 6 cylinder/turbo conversions to do in this ute?
Scheme
Postby evil_si » Thu Dec 22, 2005 9:18 pm
all depends on your budget, 2jzgte would be my pic for a 6 cylinder, other wise 1uzfe lexus v8
evil_si
Postby Si » Thu Dec 22, 2005 9:30 pm
.......insert standard issue "put a rota in it" joke...........
Current: , '96 SubaruImpreza
Si
Postby vhpacer » Thu Dec 22, 2005 9:41 pm
Haha a rota trying to tow round a hilux :lol:
vhpacer
Postby matt dunn » Thu Dec 22, 2005 10:35 pm
If I was doing one ( and I have been looking at it)
I would actually go for a 1JZGTE.
They are plenty powerful enough and way cheaper then the 2JZGTE.
On a Hilux a large single turbo conversion would be the way to go.
Not over huge Drag Racing type turbo but something mid range as the twin they come with are small and unreliable.
The hard thing will be a gearbox to suit.
Matt
Postby Scheme » Thu Dec 22, 2005 11:04 pm
what about just a 6 cylinder non turbo? 1jz-fe for example... I dont know much about the utes gearbox etc but will cutitng be required for any conversion?
Scheme
Postby fangsport » Fri Dec 23, 2005 8:58 am
S/C 3.8 buick from VN+ commodore. the adapters are available, reasonable power and a compact unit(V6 vs L6).
fangsport
Postby d1 mule » Fri Dec 23, 2005 11:07 am
dont quote me but sel te hilux and buy a late ish navara and wack in a rb26det im pretty sure they mount up to the box and engine mounts. or the lexus v8 been done heaps they go bloody good
d1 mule
Postby evil_si » Fri Dec 23, 2005 12:03 pm
d1 mule wrote:dont quote me but sel te hilux and buy a late ish navara and wack in a rb26det im pretty sure they mount up to the box and engine mounts. or the lexus v8 been done heaps they go bloody good
anything of this magnitude will require custom made mounts at the least,
and why the hell would you want to run the standard column shift navara manual with a rb26det
im doing a lexus v8 into a navara at the moment.
anything is possible, its only your budget that restricts it
evil_si
Postby KE20 » Sat Dec 24, 2005 10:27 am
a 2jzge goes fine. only thing i moded was mounts and fuel pump.
Garage Dori
KE20
Postby loose_unit » Sat Dec 24, 2005 5:24 pm
And ive got a video of that hilux sassing an SIR accord at the honda vs toyota day, pretty funny to watch.
91 GT Starlet 5efte
231kw atw @ 18 psi
12.13 @ 185kph
loose_unit
Postby strx7 » Tue Dec 27, 2005 1:27 pm
2 or 4wd?
i put a 2JZGE into my LN130 Surf. Its the bees knees. 28mpg on the highway, 21mpg towing the boat to coromandel and back. I'm using a Haltexh E6X on it, 235HP, 285Nm. Enough power to scare alot of 'performance cars' on the road. Cruise around town at 50k's in 5th gear at 1250rpm.
That being said, I put it in with the intention of turboing it in the near future and I still plan on doing it. However for what it has cost me, ya couldn't find a more competent tow vehicle for under 8-10K
Postby KE20 » Tue Dec 27, 2005 9:02 pm
mines a 2wd
strx7, did you use the 2jz factory bell, and does your ln130 have the r150f gearbox, im looking at putting a 2jzge into surf for a mate.
Garage Dori
KE20
Postby NA Drifter » Thu Dec 29, 2005 7:51 pm
strx7 wrote:2 or 4wd?
28mpg = 11.9km/L
21mpg = 8.9km/L
That's pretty good!
What about town driving?
Keith
NA Drifter
Postby quinny » Thu Dec 29, 2005 8:56 pm
i was going to put a 5mgeu in one with a w55 box, i thought it would make a good cheap conversion and the 2.8i would still tow the mint, i have all the hardware minus flywheel i think if anyone interested cos i dont have the time
currently beating - AE101 Sedan, blacktop/6spd, tein coilovers, braided lines, cup holder, and every other bloody thing possible.
quinny
Postby strx7 » Thu Dec 29, 2005 11:00 pm
28mpg = 11.9km/L
21mpg = 8.9km/L
That's pretty good!
Even better, the problem is I live only 3km from work, so i'm still running in warm up enrichment to and from work morning and night.
Most of the way to and from work i'm sitting on 50-55kph in 5th at 1250-1300rpm, I change gear around town at 2000rpm usually.
I doubt weather those figures would be possibly using the factory ecu. I tuned my E6X myself on a run in trip to auckland to watch Targa. Thru the low rpm zones, ie: below 3000rpm, at normal driving loads i'm sitting in 15-15.5:1. Under full load I'm at 13.2-13.8:1 . The beauty about owning a portable Wideband :)
Postby strx7 » Thu Dec 29, 2005 11:01 pm
I'm currently running the std 4.55:1 diffs, I reckon i could get 30mpg if i put 4.3's in it. but when towing I'd have to use 4th more so it's a gain in one book and a loss in the other. Also around town I'd probably have to use 4th.
Postby strx7 » Thu Dec 29, 2005 11:02 pm
oh yeah, if anyone had been to Baypark this year and seen the Grey Surf pushing sprint cars then they can testify as to how good it goes :)
Postby fangsport » Fri Dec 30, 2005 8:51 am
strx7 wrote:I'm currently running the std 4.55:1 diffs, I reckon i could get 30mpg if i put 4.3's in it. but when towing I'd have to use 4th more so it's a gain in one book and a loss in the other. Also around town I'd probably have to use 4th.
if you are towing at the legal limit, you shouldn't be using 5th gear anyway, same with driving around town at 50-ish km/h. it's an overdriven gear, and should only be used when necessary. hell, i don't get out of 3rd in town and only click 5th when doing 110+
fangsport
Postby strx7 » Fri Dec 30, 2005 9:47 am
90kph in 5th towing on the flat is 2250rpm, it drives around town on the flat very happily at 1300rpm. Why should I not be in that gear? there is no point being in 3rd at over 2000rpm around town, nor being at around 2700-2800 in 4th towing.
