by Big pun » Fri Dec 23, 2005 12:45 pm
is your 4k standard or has it been modified?
if its standard just go for the 3k-b twin carbs they're better than the standard 4k carby..
40mm dellortos are awesome but id only get them if your engine is worked & you have a bit of money to throw around as they are expensive to set up, you will need to get a k-series manifold (wich is about $400 brand new), linkage kit, trumpets & or air filters, + they will need to be re-jetted & tuned..
I was lucky enough to find a set that was already set up for a 4k
