tyre pressure
tyre pressure
Postby TRDmod » Fri Dec 23, 2005 12:32 pm
i have 235/17/45 on 8 inch rims, on a st205
standard suspension?
what pressure for max performance?
currently i have 35 at the front, and 34 at the rear? well thats what the tyre shop put on
i have a set of gsd3s on them
thanks guys,
Domino's Pizza.....
TRDmod
Postby cr1mnl » Fri Dec 23, 2005 1:54 pm
probably something you just have to play around with until you are happy, but what you are running now sounds about right. if you are gonna run it down the quarter you probably wanna run a smaller rim with larger profile tire ans run alot less psi for better launches and quicker times
www.ology.co.nz
cr1mnl
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
