Adydas wrote:its not frozen.. its just the ONLY key that works is ESC!! so its operationg i just cant select " Create array " and i dont know why other than the error message saying " More than 1 disk needed to make a Raid " or what ever i quoted before.. But i know from past use of SATA you dont NEED 2 disks (unless u wish to setup the raid that requires 2).
So why cant i make a single array on 1 disk?
Adydas wrote:So its not that i cant setup a RAID its that i cant setup an Array. ( i think that makes better sense ).
Adydas wrote:Last time with the same pc i still went into the same raid array setup process to make a single disk Array ( i dont belive anything to do with raid as you said thats for backup etc ).
vvega wrote:you can use a external raid controller to operate a single disc
but no onboard ones do it
Adydas wrote:I need to make the Array correct but i cant select anything on the BIOS SATA RAID thing. Its flashing the NOTICE : The Number of sicks is not enuf to cread a raid.
RedMist wrote:vvega wrote:you can use a external raid controller to operate a single disc
Actually a RAID controller with one disk is just a disk controller, you still cant setup a RAID array.
