INFO wrote:In your engine bay you will have a small Diagnostic box.
Get a little wire and bridge E1 and TE1 terminals.
Turn the car to 'ON' - Meaning don't start it.
Look at the engine check light and count the flashes and write the numbers down. Each number will mean something different.
Flashes will be as follows:
1 1 1 1........1 1 1 1 1 wich will mean Code: 45
You can check what the codes mean on this Site:
http://www.cygnusx1.net/supra/techtip/engineerrorcodes.html
pyro_sniper2002 wrote:Get the fuel pressure checked out.
