Purpose/ Importance of the throttle sensor...
Postby no_8wire » Tue Dec 27, 2005 4:48 pm
How important is it to have your sensor correctly placed/ have one at all?
Does it have much effect on fuel system?
no_8wire
Postby Ae92typeX » Tue Dec 27, 2005 7:51 pm
If you dont have one it will throw a code 7. It tells the ecu what position the throttle is at, so would affect mixture I assume.
Ae92typeX
Postby Mr Revhead » Tue Dec 27, 2005 7:52 pm
limp mode!
if its a s/c verson then no boost!
so yes, you need it and its important
Postby no_8wire » Wed Dec 28, 2005 10:14 am
so it is important to have it at the right postsion then...hmm ok...thanks
no_8wire
Postby Mr Revhead » Wed Dec 28, 2005 10:17 am
Postby Ae92typeX » Wed Dec 28, 2005 10:17 am
pretty easy to setup if yours is out, I have the specs if you dont have...
(I see Ive been bet to it)
or are you doing something else non standard?
Ae92typeX
Postby mr30%jr » Wed Dec 28, 2005 10:22 am
no8 go into clubaw go to links to good info then click on the link i posted and have a read about toyota ecu input sensors :P
it will tell you exactly what a tps does and why its important
mr30%jr
Postby no_8wire » Wed Dec 28, 2005 10:23 am
non standard... I am going to play with that idea I had about the double throttle bodies...I know it prob will have no benifit but I want to give it a go.
so some how I need to change the sensor postion so at half throttle it is sensing full throttle. I have the orignal settings for the bluetop but not the red top...
no_8wire
Postby Ae92typeX » Wed Dec 28, 2005 10:30 am
perhaps you could gear it at a 1-2 ratio
but, in using a twin throttle, wont you want it so you can wide open both also? (cant remember all the parts of you other post sorry)
Ae92typeX
Postby matt dunn » Wed Dec 28, 2005 12:55 pm
no_8wire wrote:so some how I need to change the sensor postion so at half throttle it is sensing full throttle.
WHY???
Even if you are contemplating twin Throttle body's you wont need to do this.
It measures pedal position as much as anything.
Matt
Postby no_8wire » Wed Dec 28, 2005 1:48 pm
well I thought that since at half throttle( with the double TB) it will be the same amount of air as full throttle with one TB...I would need to adjust the sensor to that this in to account...
no_8wire
Postby Mr Revhead » Wed Dec 28, 2005 2:02 pm
only if the TB was the restriction in ya airflow....
if its not the engine will still suck the same amount of air.
to be honest i really do think your on the wrong track for a stock engine
Postby no_8wire » Wed Dec 28, 2005 2:04 pm
I know Im just playing around...I start work in mid jan so I have a lot of free time... :lol:
Its giving me something to do...just like the hood and lid mods that im doing..
no_8wire
Postby Mr Revhead » Wed Dec 28, 2005 2:06 pm
ok
then what id do is just hook up one TPS. itll still tell it where 1/4 1/2 and full throttle is. and itll only suck in the air it needs. and seeing as its MAP sensor it measures the air in the manifold....
Users browsing this forum: Google [Bot] and 20 guests
