purpose of steel plate between 4age - T50 ?
Postby AE85.6 » Tue Dec 27, 2005 9:18 pm
while doing my gearbox and clutch mission i noticed that the steel plate that goes between my enigne and gearbox is not the same flange pattern so two bolts under the starter motor dont line up, can i just reslot or drill the holes where needed or how vital are these plates to have ?
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby fangsport » Tue Dec 27, 2005 9:59 pm
the plate stops cerap from entering the bellhousing and clutch mechanism, it also ensures the block stays are lined up with the bellhousing. sounds like you have the wrong sandwich plate for the bellhousing/starter combination. redrill the holes for starter.
fangsport
Postby KinLoud » Wed Dec 28, 2005 8:13 am
The metal sandwich plate...
- locates the starter using the big round hole and the holes that the dowels fit through, the 2 bolt holes aren't critical.
- keeps crap from getting into the clutch
I would be curious to know why it isn't the right one in the first place?
Ken
Ham
021 408 863
Postby fangsport » Wed Dec 28, 2005 9:25 am
there are 2 different starters that are used with the T-50. there is the soliniod type and reductiion gear type
fangsport
Postby AE85.6 » Thu Dec 29, 2005 8:28 am
KinLoud:
ye im curious too, but parts could have been scarce at the time my 85.6 had all its crap swapped over or someone thought it fits so thats good enough, i dunno the engine and gearbox was done when i bought it so there is still alot of things i find out along the way.
AE85.6
Postby sk1dlet » Thu Dec 29, 2005 8:55 am
cud it b a k50 sandwich plate?
82 4DR KP62 4AGTE MADNESS
98 RS200 ALTEZZA
sk1dlet
Postby AE85.6 » Thu Dec 29, 2005 9:57 am
id say so,
think ill just try slot/drill them.
cheers all
AE85.6
