sergei wrote:In my opinion you will not gain much at all from just a head gasket job, as silvertop barely runs on 95 (unless you retard ignition), little better on 98 gas (but still can get ocasional knocks under low rpm high load), when you going to up the compression (although not by much) you will defentely need to either run better gas or retard igniton (which will lead in loss), otherwise it will knock alot..
Is there anything thicker than 0.8 in metal
