by sergei » Tue Dec 27, 2005 11:55 pm
when cam belt snaps - I assume your is 3STGE (non interference and assuming no dropped valves), it will result in sudden engine braking (similar to fuel cut), but you still have electrics/power steering (as long as engine still rotating), as electrics should run off battery anyway... maybe your battery shorted itself inside hence pophiss noise and no electrics. Did you smell anything when it happend ("rotorua" smell???)
