overfuelling
overfuelling
Postby :madaz: » Wed Dec 28, 2005 3:42 pm
we all know what leaning out can do to a (especially) turbo car but on the other side of the scale, how major damage can be done by running far to rich?? is it possible to melt pistons running rich?? what other bad symptoms does a rich running engine gain if not tuned ??
speed on brother
hell aint ful yet
:madaz:
Postby Ae92typeX » Wed Dec 28, 2005 3:45 pm
bore wash...its just as bad in the end (just in different ways)...still means a rebuild.
Ae92typeX
Postby Si » Wed Dec 28, 2005 6:12 pm
As far as i remember anything below about (there are lots of variables here) 8:1 air fuel will cause the borewash issue
If you cant afford tuning then be aware that your burning more fuel than you probably need to, therefore its costing you money :)
Current: , '96 SubaruImpreza
Si
Steal it if you can :))
Postby jondee86 » Wed Dec 28, 2005 6:53 pm
It's amazing what you can find on the internet. This for example....
A FULLY WARMED UP ENGINE WITH AN A/F RATIO AS RICH AS
6.0-1 AND AS LEAN AS 22.0-1, THESE ARE THE GENERAL RICH AND LEAN
COMBUSTION LIMITS, BUT DURING ACTUAL DRIVING SITUATIONS THE
ACTUAL A/F RATIO NEEDED DURING VARIOUS OPERATING CONDITIONS
WILL BE VERY CLOSE TO THE MID-POINT OF THESE EXTREMES.
A/F RATIO / COMMENT
9.0:1 BLACK SMOKE (NO POWER)
11.5:1 RICH BEST TORQUE @ WOT
12.2:1 SAFE BEST POWER @ WOT
13.3:1 LEAN BEST TORQUE @ WOT
14.6:1 STOCHIMETRIC AFR ( CHEMICALLY CORRECT )
15.5:1 LEAN CRUISE
16.5:1 BEST FUEL ECONOMY (EXCEPT FOR HONDA)
18.0:1 CARBURETED LEAN LIMIT (EXCEPT FOR HONDA)
22.0:1 EFI LEAN LIMIT
GENERALLY ENGINES OF DIFFERENT BASIC DESIGNS HAVE THE SAME
A/F RATIO REQUIREMENTS. THESE CALIBRATION NEEDS ARE TYPICALLY
A FUNCTION OF OPERATION MODE, ENGINE TEMPERATURE, ENGINE
SPEED, AND LOAD. GENERALLY A PRODUCTION BASED HIGH
PERFORMANCE ENGINE WILL HAVE A/F RATIO VALUES IN A RANGE FROM
12.0:1 TO 16.0:1.
This info is stolen from a Toyota high performance site, so I don't know
about the Honda comments. Maybe Honda have better lean burn
technology ??
Cheers.... jondee86
Watch this space >>> <<<
jondee86
