3SGTE into ae92 :D
3SGTE into ae92 :D
Postby Brick » Thu Dec 29, 2005 9:34 pm
well ive been talking to Al and this seems like a cool little project for me..
but wat i need to no is how much effort it is and will it be worth it?
my main issue is making new supports/bracket/mounts thingies but everythin else my mate can do.
any help about it will be good :P
Brick
I know Kung Fu
Postby Al » Thu Dec 29, 2005 10:12 pm
What did you talk to me about? :lol:
All I can see a 3s doing in an ae92 is fry the tyres :lol:
Al
Postby Brick » Thu Dec 29, 2005 10:17 pm
dont you remember? at work :? it was u that gave me the idea!
just finished reader fasterthanjesus 8) very good info
so will the 3s fit straight onto my g/box then :?
there only tires :lol: :lol:
Brick
I know Kung Fu
Postby mr30%jr » Thu Dec 29, 2005 11:30 pm
um mr2 turbo gearbox is what you need :P
you might get away with a celica gtr one :?
throw some s series cv ends on you drive shafts and you awat laughing or skidding in ur case
mr30%jr
Postby Brick » Thu Dec 29, 2005 11:37 pm
mr30%jr wrote:um mr2 turbo gearbox is what you need :P
will i hav to do any other work to the arms or struts etc?
Brick
I know Kung Fu
Postby Malcolm » Thu Dec 29, 2005 11:47 pm
it is for people like you, that I have written this:
http://www.fasterthanjesus.net/technical/fwd3sgte.html
Postby Brick » Thu Dec 29, 2005 11:56 pm
All_Fours wrote:it is for people like you, that I have written this:
Brick wrote:just finished reader fasterthanjesus very good info
:wink:
just some other little stuff i had to clear up on :P
Brick
I know Kung Fu
Postby Akane » Fri Dec 30, 2005 12:03 am
in a FWD you'll be better off with a 4A-GZE turbo'd.
The torque in a 3S-GTE will just make you fry tires all day long.
Postby Brick » Fri Dec 30, 2005 12:05 am
i plan on putting the gze into another fxgt. the levin woudnt be the daily driver, it will just be for like drags or wat ever, so ill prob get DOT's
but skids are all good :lol:
Brick
I know Kung Fu
Postby Malcolm » Fri Dec 30, 2005 12:10 am
oops, didn't read thoroughly enough
so what other things would you like to know? Suspension arms should all be fine, the 3S-GTE isn't significantly larger than the 4AGE, so physically fitting should be no major issue, the intake manifold vs. firewall is the main contention, I'd imagine
Postby Brick » Fri Dec 30, 2005 12:16 am
my main problems will be mounts, but im sure ill find/pay someone who can do them.
i been told to use the Gt4 engine with the mr2 gearbox?
so if that is really about it it shudnt be to much of a big job :? ??
Brick
I know Kung Fu
Postby Malcolm » Fri Dec 30, 2005 12:32 am
yeah the gt4 engine will be a good idea, that way you have wiring harness etc ready for FWD config. I can get you a GT4 gear selector linkage thing for converting the MR2 box if you like, just let me know and I will sort it.
It wont be all that easy, but if you take a methodical approach it shouldn't be overly difficult. If you read through my swap diary you'll see some of the problems that you might have to overcome, and add a little more for the difficulties outlined below:
Positioning the engine will take some time, and the wiring could take some time, since you have quite a bit of wiring going to the fusebox in a FWD.
If you want to use/keep power steering then you will possibly need to get custom hoses made up to go from the GT4 pump to the AE92 system.
Postby RomanV » Fri Dec 30, 2005 12:35 am
"THASHZ" Has done this very conversion, (Or was it into an ae82?) he would be a good person to talk to, if you could get hold of him. 8)
