20v Engine Check
20v Engine Check
Postby XS1V » Wed Jan 04, 2006 5:03 pm
In my ae82 with a 20v silvertop i was coming back from hahei when we stoped at thames. When i turned the car back on the check light was on and it was in limp mode. I disconnected the battery and reset the computer and it ran fine till the next time we stopped and it happened again when starting.
It has also started over heating now and after trying a diagnostic code (bridging E1 and Te1) it flashed non stop.
What to do? Anyone had a similar problem?
ST205 Group A Rallye #2363
XS1V
Postby Adydas » Wed Jan 04, 2006 6:20 pm
If it flashed non stop you didnt do it right i dont belive. Do it again its a bit of a pain to do.
Adydas
Postby AceSniper » Wed Jan 04, 2006 6:35 pm
if you suspect its the ecu iv had and seen problems with two capacitors leaking in them, just replace them, but check everything else first
AceSniper
Postby sergei » Wed Jan 04, 2006 7:06 pm
Sometimes it can come up with engine check light but not actually log it...
Postby Distrb » Thu Jan 05, 2006 1:00 am
IIRC, the non stop flashing of the engine check light mean that there is no code
Distrb
Regular Poster
Postby deaf_rattle » Thu Jan 05, 2006 9:44 am
http://forums.toymods.org.au/index.php? ... msg_214425
that might be worth a read.
is the motor actually over heating? or is the gauge just telling you that it is?
Postby XS1V » Sun Jan 15, 2006 2:55 pm
Distrb wrote:IIRC, the non stop flashing of the engine check light mean that there is no code
Yea i dont think it was logged, have pretty much put it down to a low water level due to the over heat which causes the engine light to turn on.
deaf_rattle wrote:is the motor actually over heating? or is the gauge just telling you that it is?
Yup its definately over heating, using water and steaming after long drives on hot day etc :S
Thinking maybe thermostat? Possibly somthing to do with it running rich with the bung injectors but i dont know
XS1V
