ae91 4age conversion
Postby jeremy » Fri Jan 06, 2006 12:23 am
i know this has been covered but i cant find what im looking for
any way ive got a 91 levin and a ae92 donor car
ive got the mechanical side sussed
i just need to know how to wire it up, idealy id like to keep the factory dash/instrament cluster
and is there anyway to lock the tems in hard with out swapping the module and wiring over (1/2 the wirings been hacked)
this is the first efi conversion ive done
thanks for your time
jeremy
jeremy
Postby crispy'86 » Fri Jan 06, 2006 7:22 am
crispy'86
Postby Ae92typeX » Fri Jan 06, 2006 8:36 am
for the tems, if you take the actuators off, you can then set to hard manually (off memory, I cant recall which way to turn them). You would want to place the top back on that setting or secure it somhow just incase they get knocked off the hard setting.
Ae92typeX
