Cam Specs. 2JZ vs 1JZ
Postby Silent Knight » Fri Jan 06, 2006 12:12 pm
Does someone here have the specs on the stock cams for these two motors?
I need the specs JDM specs for both the 1JZ-GTE and 2JZ-GTE and also the US specs for both of these motors.
Cheers for the help.
Silent Knight
Postby Si » Sat Jan 07, 2006 4:30 am
i have the info somewhere,
if your thinking of 2j cams into 1j i have a strong feeling its not really worth while.
RANDOM GOOGLE INFO
I knwo the the 1JZGE cams are different to the 1JZGTE cams in the front shaft seal size and also the camp angle pickups...
1jz turbo
Intake cam timing (o-c) : 3° BTDC - 41° ABDC
Exhaust cam timing (o-c) : 46° BBDC - 2° ATDC
Camshaft duration : 224 (in) 228 (ex)
http://forums.toymods.org.au/index.php? ... msg_109352
http://www.supraforums.com.au/forum/arc ... php/t-4956
Current: , '96 SubaruImpreza
Si
Postby Silent Knight » Sun Jan 08, 2006 10:34 pm
Mixed opinions...I have heard otherwise.
Someone have all teh full details available somewhere?
Revhead...you should all of the details or don't you guys keep the US specs?
Silent Knight
Postby Si » Sun Jan 08, 2006 10:38 pm
i suppose even if the cams didnt fit you could put the whole head on :P
Si
Postby Silent Knight » Sun Jan 08, 2006 10:43 pm
Si wrote:i suppose even if the cams didnt fit you could put the whole head on :P
Why would I want to downgrade to a 2J head...? :P
Silent Knight
Postby Si » Sun Jan 08, 2006 10:46 pm
i dont think there are real propper benchmark figures that say a 2j head is any worse than a 1j head
Si
Postby gmacrae » Sun Jan 08, 2006 11:32 pm
Oh christ, here we go. This has been discussed many times in the past overseas, and the final conclusion always drawn is that the flow tests are never conducted accurately enough, usually comparing a tweaked 1j head to a stock 2j head or vice versa. The myth that the 1j outflows the 2j head was started a long time ago by a jealous 1jz owner trying to prove his was actually a better engine than the 2jz he secretly desired - though he'd never admit that to his soarer/mk3 buddies :lol:
I mean, lets be serious here. Why would toyota design the head for the smaller, lower hp engine to flow better than the flagship model? To me it makes perfect sense that they flow exactly the same, just because its easier to design and build like this.
1) Dont waste your time replacing your stock cams with more stock cams - you'll never get any decent gains
2) If you're wanting more hp, more parts are made for the 2jz anyway (manifolds, cams etc)
Gene
gmacrae
Postby Si » Sun Jan 08, 2006 11:35 pm
yamaha designed the 1j
toyota designed the 2j
Si
Postby 3VLTOY » Mon Jan 09, 2006 1:11 am
Now now boys how bout we all go back to the top of this thread and read the original post? :P
I'm sure if you look a question was being asked not your own opinions on shit you either do or by the ooks do not understand.
If you know the answer to the above question it is appreciated if not then don't post :lol: :lol:
3VLTOY
Postby Adamal » Mon Jan 09, 2006 8:43 am
The whole 1J head on a 2J block comes down to cost, if I recall correctly.
A complete 2JZGTE engine costs mega bling, whereas it was cheaper to buy a 2JZGE block, rework the internals and use a 1JZGTE head.
Anyway, as for the cam differences:
I HAVE NO IDEA!!!!!
Postby Silent Knight » Mon Jan 09, 2006 8:45 am
The myth that the 1j outflows the 2j head was started a long time ago by a jealous 1jz owner trying to prove his was actually a better engine than the 2jz he secretly desired - though he'd never admit that to his soarer/mk3 buddies Laughing
Right well thank you for the nice bed time story and what seems to be a very educated piece of BullShit information...
I did not start this thread to argue with meatsacks over which head is better I am asking for the differences between the cams for the US and JDM spec 1 and 2JZ's.
If you can't contribute then please feel free to piss right off...
Silent Knight
Postby Mr Revhead » Mon Jan 09, 2006 11:56 am
sorry man dont have the info, we got nothing on the JZs here
so im gunna piss off :P
Postby vvega » Mon Jan 09, 2006 6:24 pm
pissed off like a condom ??
i feel used :(
v
vvega
Postby Silent Knight » Tue Jan 10, 2006 11:52 am
Right...I've found out the specs on the 2JZ but I still need the 1JZ specs if anyone can help.
2JZ-GTE:
224 degree (JDM) 7.8mm Lift
233 degree (US) 8.25mm Lift
Good site for the specs: http://mkiv.supras.org.nz/specs.htm
Silent Knight
Postby fivebob » Tue Jan 10, 2006 12:25 pm
This may, or may not, be of some use to you.
http://my.is/forums/archive/index.php/t-273060.html
Postby Silent Knight » Tue Jan 10, 2006 12:59 pm
Thanks fivebob but the only info they have on cam duration for the 1J on there is for the N/A. :?
Silent Knight
Postby Si » Tue Jan 10, 2006 9:15 pm
are the toyota part numbers different for the jdm and usdm cams?
Si
Postby Mr Revhead » Tue Jan 10, 2006 9:43 pm
exhaust cam is different jdm vs usa.
tell me what the the 1jzgte came in in the states and ill look it up
Postby Si » Tue Jan 10, 2006 9:52 pm
i was under the impression the 1jz didnt come out as USDM untill the vvti ones came about,
did a quick search couldnt find anything
maybe someone else knows
Si
Postby Silent Knight » Tue Jan 10, 2006 10:02 pm
Hrmmm yea I think that might be the case aswell...I've only ever heard of the VVT-i Single Turbo 1J in the states aswell.
Well if that is the case then anyone know the duration for the JDM 1JZ cams?
Silent Knight
