u4dina wrote:one thing i did notice is that when i pull hard on the acelerator cable it chokes and stalls the engine and my boost guage is not at 20 as it usually is when on idle it's gone up to 10 (this is before boost)im not quite sure what that means tho.
u4dina wrote:Im told it could be an ecu problem......I've been told the computers on these things have been known to trip out..
u4dina wrote:I have to slowly pull on the accelerator cable before the revs goes up which takes quite a few seconds... if i do it to quickly it just stalls.....
Hey fivebob is it a big job to change the broken rings lands if that was it
but i can easily check the compression...what is a leakdown test..??
Ring Land = area of the piston between the rings. So new piston,rings head gasket and a few hours to do the job
Akane wrote:Do a compression test 1st.
u4dina wrote:I just did a compression test on the caldina and all cylinders are running on about 170psi
Akane wrote:Then check for coil (spark)
u4dina wrote:it seems all the cylinders are going just its not running smooth at all cos i've tried to pull each plug out at a time and each time i pull it out the car really starts shaking.......
fivebob wrote:
u4dina wrote:I can see the sparks but it dosn't look that strong at all and i alsoo changed new iridium plugs on it today...
