ke35 corolla cigerette lighter wiring
Postby l1ttle_d3vil » Sun Jan 15, 2006 6:11 pm
what wires should be connected to my cigerette lighter in my ke35?
it doesn't work at the moment, and there are no wires going to the back of the lighter at all. should there be one or two?
there is a round bit of metal sticking straight out the back, and also a flat piece of metal off the side of the lighter. which of these should have a terminal going to them?
also, if you could tell me what colour the wires are meant to be that'd be helpful; it is a 1975 model sr coupe.
cheers.
sr
Postby ATOYOTA » Mon Jan 16, 2006 10:36 pm
there is usually a earth wire on the base
and a power wire on the middle
ill hav to ask my mate hes got one
for the colours if u want them the wires will b there
sumwhere tucked away no doubt
it u hav 2 wires there put the black on the outer case
if u hav a test lite conect it to earth and test the power source and turn the ign on to check if u hav power
conect it and try it
ATOYOTA
Postby vhpacer » Tue Jan 17, 2006 2:37 pm
I'm 99% sure they are black and blue. But I'll check for sure tonight
vhpacer
