weird rubbing/knocking noise
Postby escortman » Mon Jan 16, 2006 12:04 am
no not from teh engine :lol:
but ever since i put lowered springs in my ae82 fxgt wen i turn right and the weight transfers to the left of the car somethign in the front and back sounds lik its rubbing and knockin, wat could this be i replaced the shocks with some newer 1s and it still does it, could it be some joint in the front but wat could do it in the back :?:
escortman
Postby Kender » Mon Jan 16, 2006 1:05 pm
Take a look at the top of the struts while the car's weight is on them. Is the nut on top of the shock snug against the top plate. The last shocks I fitted made a lot of knocking sounds when I used the new nuts that came with them. I fixed this by using the original nuts I'd removed from the old shocks.
'84 AW11 SC racecar "RDDWRF"
'92 SW20 GT-S
'91 GT Legacy wagon
Kender
Postby Ae92typeX » Mon Jan 16, 2006 6:50 pm
Could be many things...check all the arches and plastic shield material- its not uncommon to rub on them when lowering a car. Knocking could be the shocks bottoming out- even if new- especially if they are standard height ones. As above, check all mount bolts are secure. Also could be swaybar bushes flogged out- again not uncommon.
Ae92typeX
Postby escortman » Mon Jan 16, 2006 7:05 pm
nah i know its not the shocks bottoming out i was very acustom to that b4 replacing them, i know the frotn right wheel rubs occationally wen in certain situations :P im gona check the rest on weekend, how do i check if the swaybar bushes have had it
escortman
Postby THA SHZ » Mon Jan 16, 2006 9:57 pm
wot sort of wheels do u have on it ? :?
THA SHZ
Postby escortman » Mon Jan 16, 2006 10:00 pm
jus 13s hubcaps 185/60s
escortman
