4age or 4afe
4age or 4afe
Postby The Game » Thu Jan 19, 2006 10:00 pm
k just wondering, i have a twin cam 16 v 1600cc trueno. theres been alot of discussion over whether it is 4afe or 4age. Anyone keen to enlighten me?
The Game
Postby Scotty » Thu Jan 19, 2006 10:01 pm
it should say on the build plate on the firewall and the end of the engine
Scotty
Postby The Game » Thu Jan 19, 2006 10:07 pm
? ok
The Game
Postby mycoolcar » Thu Jan 19, 2006 10:19 pm
Its a silver plate, just down from the windscreen inside the engine bay. Look at it and on there somewhere it will say either 4age or 4afe, that will tell you what the engine is.
mycoolcar
Postby Santa'sBoostinSleigh » Thu Jan 19, 2006 10:36 pm
or look on the cam cover, may say there
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby Leon » Fri Jan 20, 2006 7:45 am
4afe
4afe
4AGE
4AGE
Postby Alex B » Fri Jan 20, 2006 1:08 pm
The 4a-fe may lok slightly diffrent to the one pictured as they changed the rocker cover between ae92-101 :)
Postby Truenotch » Fri Jan 20, 2006 3:28 pm
Sounds like it's probably a 4age if it's called a twincam 16v as a 4afe is usually just called a 16v efi because of the way the head is layed out. 2 cams and 1 cam gear (correct?).
Truenotch
Postby Alex B » Fri Jan 20, 2006 3:34 pm
I would think so, althought a 4a-fe is twin cam. Ive herd people say they are not, i spose it depends if you take twin cam to mean cam gear or cam shaft.
Postby Leon » Fri Jan 20, 2006 3:41 pm
Both GE and FE are DOHC / Twin Cam 16 valve and can be referred to as such.
Do you have your car there? If so, when does the redline on the rev-counter start? That will tell us what the motor is, without you even having to open the bonnet.
Postby Santa'sBoostinSleigh » Fri Jan 20, 2006 3:43 pm
Leon wrote:Both GE and FE are DOHC / Twin Cam 16 valve and can be referred to as such.
you are one wise-(funny looking) man Leon
Santa's Mega Sale
Postby Caveman » Fri Jan 20, 2006 3:55 pm
pyro_sniper2002 wrote:I would think so, althought a 4a-fe is twin cam. Ive herd people say they are not, i spose it depends if you take twin cam to mean cam gear or cam shaft.
If its got two overhead cams its dohc aka twincam
Caveman
Postby Adamal » Fri Jan 20, 2006 3:56 pm
4AFE may appear not to be DOHC because it only has one cam being driven by the cam belt, as the other one is done by a gear between the two cam shafts.
Postby touge rolla » Fri Jan 20, 2006 7:24 pm
the way the cylinder head is layed out in a 4afe is similar as to in most quad cam v6 and v8 engines with 1 external cam gear driving both camshafts, unscrew your oil filler cap and if there is a cog beneath it u've got a 4afe if its a cam u can see its a 4age
touge rolla
