the celica is stuffed
Postby 1loose_mr2 » Mon Jan 23, 2006 4:43 pm
its making bad noises coming from the left side around the diff area,its so bad that i cant even move it.whats the most comman thing to break in the celica.is it the gearbox,diff,cv does anyone know.
1loose_mr2
Postby Punter » Mon Jan 23, 2006 4:52 pm
Might pay to describe those "bad" noises a little better.
-What does it sound like when running with the clutch in?
-Can you select gears with the clutch in (ie. full movement of the gearstick)?
-Does it stall when you let the cluch out or just make "bad" noises?
(That is assuming its manual)
also what were you doing when it started happening?
Punter
Postby 1loose_mr2 » Mon Jan 23, 2006 5:35 pm
runs fine with the clutch in
i can select gears with the clutch in
it just makes real bad noises when you try to move it
the noise seems to be coming from the diff area
its manual
1loose_mr2
Postby Adydas » Mon Jan 23, 2006 5:43 pm
Sounds like the bearing.
Adydas
Postby 1loose_mr2 » Mon Jan 23, 2006 6:02 pm
from where
1loose_mr2
Postby Punter » Mon Jan 23, 2006 6:11 pm
1loose_mr2 wrote:from where
Your gearbox.
Punter
Postby 1loose_mr2 » Mon Jan 23, 2006 6:18 pm
how hard is it to change a gearbox or what would it cost to take it to the workshop?approx cost.
1loose_mr2
Postby GT4 20 » Mon Jan 23, 2006 8:18 pm
Which model Celica?
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby 1loose_mr2 » Mon Jan 23, 2006 8:51 pm
st183
1loose_mr2
