20v turbo
20v turbo
Postby ATOYOTA » Tue Jan 24, 2006 10:25 pm
hey guys my mate has a levin 20v
anyway he wants to turbo it now as far as i am aware the rods
are the same as a gtz and same as the block
so i would need some pistons gtz or forged
i would need a gtz sump iam assuming for oil return
how do i get a oil feed to the turbo
what kind of turbo is suitable
gtz injectors and pump
can u use the factory air direction maniold on the 4 throttle bodys
under boost or does it split
ecu can it be used would like to remove that big ugly afm any way
any help would b mint
im guna start this wknd
ATOYOTA
Postby Si » Tue Jan 24, 2006 10:33 pm
s
e
a
r
c
h.
theres a search button at the top of the page, click it and type turbo 20v. or whatever else you need.
Current: , '96 SubaruImpreza
Si
Postby Lloyd » Tue Jan 24, 2006 10:36 pm
Have a search first, plenty of info.
Assuming its a silvertop you'll be wanting GTZ pistons as far as internals go.
You wont need a GTZ sump as it doesn't have an oil return, you'll have to modify your original sump.
Get an oil feed from the oil pressure sender in the block by the oil filter (single wire running to it probably)
GTZ injectors are top fed where as 20V are side fed so you'd be best finding some 3SGTE injectors to fit.
Factory inlet will split, you'll want something made up to suit if you're wanting to stick with quad throttles.
ECU would need to be aftermarket
Fair few turbos you could use, TD04 on the very small side of things, T3, GT25/8, TD05 etc etc
Again, have a search
