I'v been looking to upgrade the rear sway bar in my BZ-T carib as the back is all over the show when cornering. I'v found that whiteline make afew applications at a fair price. I have a 80-100 kg sub box in the rear would i need to go to the extent on a extra heavy duty or would this be a over kill. The front of my car rides very hard which i like, i have replaced the shocks in the rear (which is running king springs) but its still very sloppy would a sway bar fix this problem.
Would i be correct in saying that the AE111 Carib runs all the same rear suspension as the BZGs, would this be why its so soft in the back and why king springs are even too soft?
Would i be better to go for a extra heavy duty in this case then taking into account that its alot heavier then a bzg
