Pod filter and sensors.... don't bite me i searched first!
Postby SpeedRacer » Wed Jan 25, 2006 6:02 pm
ok here is the dilema...
This pic shows the intake pipe, and a couple of sensors (sorry for bad pic, took it with my crap fone :( )
does it matter where i drill a hole in the intake pipe for the green sensor ie does it matter if its after that vaccum hose?
This is all cos im too cheap to get a stainles bling pipe made, howeva if the position of the sensor matters can some one (pref close to palmy) make me one with the appropriat holes for sensors?
Sinister Sleeper 35
SpeedRacer
Postby Ae92typeX » Wed Jan 25, 2006 6:48 pm
If you are just going to fit the pod to the end of the hose then just drill the hole into the hose on the other side of the clamp pictured.
it would be better (if you were to ever go back) to make an adapter length- even out of pvc or something and make a fitting into that as well as a cold airbox for the pod...but the above will work anyway
Ae92typeX
Postby SpeedRacer » Wed Jan 25, 2006 6:52 pm
cheers, hadn't hought of that or in that way
Speed
Sinister Sleeper 35
SpeedRacer
