g52 gearbox
g52 gearbox
Postby phrogmodz » Wed Jan 25, 2006 8:57 pm
can anyone tell me about the internals
in the g52 and how they compare to the w55?
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby phrogmodz » Thu Jan 26, 2006 8:06 pm
bump
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby KinLoud » Thu Jan 26, 2006 9:09 pm
My understanding:
G series use very similar case to the W series. Same front bolt pattern so will bolt to any W55/56/57/58/59 bellhousing.
Same strength I'm told.
Ratios some are similar/same as the W55, others have up to 3.9:1 1st gear.
Ken
Ham
021 408 863
Postby KE20 » Fri Jan 27, 2006 5:52 pm
the G52 has bigger bearings. and the gear stick is further forward than the w55.
Garage Dori
KE20
Postby phrogmodz » Fri Jan 27, 2006 10:05 pm
cool
cheers for that guys
1992 ln130 surf 2jz
nz ae101 wagon
phrogmodz
Postby Quint » Mon Jun 21, 2010 1:49 pm
Resurrect.
Anyone know the spline count on the input shaft and the usable flywheel dia on the G52?
Cheers.
Quint
Postby 2LTR Rona » Mon Jun 21, 2010 2:38 pm
Quint wrote:Anyone know the spline count on the input shaft
Have one collecting dust in my basement, can count the spline tonight if ya like
2002 Altezza, 1974 KE25
2LTR Rona
Postby Bazda » Mon Jun 21, 2010 3:58 pm
W55 etc and E series boxes are 21T with a diameter of ~29mm.
Postby Quint » Mon Jun 21, 2010 6:09 pm
That'd be choice thanks.
Thought W55s were 22t?
Edit, went and counted, you were right, 21 :)
Quint
