Wiring diagram
Wiring diagram
Postby opticalblue » Thu Jan 26, 2006 10:35 pm
Hi does anybody have a wiring diagram for the ecu as i have a loom im trying to wire up but some one has taken one of the plugs off the ecu and im trying ti wire up a new plug but the colours are a different colour for a 4age with a map sensor of a mr2 my ecu number is 89661 17020
Thanks
opticalblue
Postby opticalblue » Fri Jan 27, 2006 5:37 pm
bump... all i need is the wiring diagram of the plug with the 14 pins and in what order...
thanks
opticalblue
Postby KE20 » Fri Jan 27, 2006 5:50 pm
if you open it up, it should list on the circuit board what each pin does.
Garage Dori
KE20
Postby opticalblue » Tue Jan 31, 2006 11:22 pm
yeah i have opened the computer and its doesnt say what pin goes to what colour wire i just need someone with a 85 mr2 with a 4age to tell me ir have a look on the plug with 14 pins to what orger the pins to colour wire they are.... :?
opticalblue
Postby Rick » Tue Jan 31, 2006 11:33 pm
Try this, its for a ae86 but shoud be the same, just double check.
http://www.club4ag.com/faq%20and%20tech_pages/ECU%20Japan%20AE86%204A-GE.htm
Postby opticalblue » Wed Feb 01, 2006 6:28 pm
thanks rick ill check it out...
opticalblue
Postby opticalblue » Thu Feb 02, 2006 8:00 pm
the ae86 diagram is a little diferent... does anybody have a mr2 they could help me on...thanks :?
opticalblue
Postby opticalblue » Fri Feb 10, 2006 3:33 pm
bump
opticalblue
Postby matt dunn » Fri Feb 10, 2006 7:54 pm
opticalblue wrote:the ae86 diagram is a little diferent... does anybody have a mr2 they could help me on...thanks :?
no the AE86, AW11 MR2 and the AE82's all have interchangable ecu's.
Postby Stealer Of Souls » Fri Feb 10, 2006 11:03 pm
Different wire colours?
'86 AE85.5 Levin
Stealer Of Souls
Postby opticalblue » Fri Feb 17, 2006 4:16 pm
well ive undone the whole loom and see that most of the wires from the 14pin plug run... im guessing for the light on the dash or so and one green one to the main relay and none to the sensors.. so does anybody know what they are...
thanks
opticalblue
Postby ee904age » Fri Feb 17, 2006 6:48 pm
That plug only goes to the dash. I cant help as far as what pin goes where, but I put a 4AGE into my carb'd AE82, and left that plug out. You dont need anything connetcted to it to run the engine. I just used the factory dash loom connected to the appropriate sensors on the 4AGE
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby matt dunn » Fri Feb 17, 2006 11:08 pm
ee904age wrote: You dont need anything connetcted to it to run the engine.
Ahh, you sure? I think not.
The only ones you really need are the three power supplies, and if you want the fuel pump sw and the warning light.
Postby ee904age » Mon Feb 20, 2006 11:09 am
Ahh yeah, Sorry. Matts right, i ran the fuel pump off ign feed, but the minimum you will need are the three power feeds.
90 SW20 N/A - Sold
ee904age
Postby opticalblue » Wed Feb 22, 2006 9:35 pm
does anybody know what the colour are these...
the warning light and the fuel pump...
ive got the three power wires...
opticalblue
