Distributor help!!!!
Postby wildchild » Sat Jan 28, 2006 6:03 pm
can't remember what wire a Tach connects to on the distributor
(group 1)there are a group of about 4 to 6 wires . (group 2) then a little bit lower there are 2 wires a black one and a red/black one
i have a feeling it is the black one out of the 2nd group of wires
HP is how hard you hit a wall, torque is how quickly u get there!!!!!!!!!!!!!!!!!
wildchild
Postby gepsk8 » Sat Jan 28, 2006 7:19 pm
get a test light put postive feed on it. then put into the wire u think it is. it should flash on and off when u start the car up. if u need more help pm.
gepsk8
Postby slighty_sykotic » Wed Feb 01, 2006 4:46 pm
Or could tap into the tach feed in the diaginosis connector if it has one. Nice and easy to find, its even labeled most times :)
--Sykotic
slighty_sykotic
