BOV on supercharger
BOV on supercharger
Postby Brick » Sat Jan 28, 2006 9:08 pm
can this work? saw Andy7447 BOV setup on his top mount (3sgte) so would it work on my s/c?
Brick
I know Kung Fu
Postby CozmoNz » Sat Jan 28, 2006 9:23 pm
Short answer nope.
Rayne For President!
CozmoNz
Postby DB4G63 » Sat Jan 28, 2006 9:49 pm
Ok Why would you need a BOV on a supercharger?
Superchargers dont tend to build up the pressure, its based on how fast they are spinning, so theres no release off excess boost... or "Pissssssssshhh!"
However my GTZ when I bought had a turbo timer.... shows how little people know about the old roots blower....
"If I'm a child that means you're a pedophile, and I'll be damned if i'm going stand here and take this from a pervert."
Wheels: AE101 1993 GTZ Trueno (S/C)
DB4G63
Postby Brick » Sat Jan 28, 2006 9:53 pm
DB4G63 wrote:Ok Why would you need a BOV on a supercharger?
why not :)
o well was worth a try
Brick
I know Kung Fu
Postby no_8wire » Sat Jan 28, 2006 9:55 pm
Why would you want one? "bling" factor?
no_8wire
Postby Rick » Sat Jan 28, 2006 11:57 pm
I am going to be running a BOV on my ZE powered AE85, but I am not going to be using the factory setup the t/body is going to be after the supercharger which is why I need a bov. Tim has one in his ZE powered ae86.
Postby Mr. Mainstream » Sun Jan 29, 2006 12:46 am
No Skank Whistle For Brick :P
75 MK2 Ford Escort L 2.1L
Various Others
Mr. Mainstream
Postby dash » Sun Jan 29, 2006 6:07 am
interesting setup Rick
Is that pipe stickin up to the side for the air cleaner ?
Which SC do you have ?
The stock ze induction is a compact package, but some claim restrictive. Is that the reason you went with the tb after the sc arrangement ?
When you look at the impressive results miata guys get from their various add-on superchargers... it really seems worthwhile, and something I may wanna try on my spare gze just for kicks.
dash
Postby beeker » Sun Jan 29, 2006 8:23 am
Rick wrote:I am going to be running a BOV on my ZE powered AE85, but I am not going to be using the factory setup the t/body is going to be after the supercharger which is why I need a bov. Tim has one in his ZE powered ae86.
I was gonna say that. Tim ran hybrid SC12 setup and had ~122wkw at the wheels. He has (or had) some of his bits on trademe now.
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby Rick » Sun Jan 29, 2006 9:41 am
That isn't my setup, but I can answer your questions, the pipe up the side is where air is sucked into the supercharger, I dont think tim runs a air filter, on his setup he has a SC12 supercharger.
dash wrote:The stock ze induction is a compact package, but some claim restrictive. Is that the reason you went with the tb after the sc arrangement ?
I feel that the factory setup is quite restrictive, and the factory top mounted intercooler is a joke, but it is all a compromise, to fit a different less restrictive setup into fwd cars etc.. would be costly and in fwd format there is just not enough room, but when in a rwd this allows more room and the factory setup can be changed for a less restrictive one and the reasons I have the t/body in my setup after the supercharger is that Iam using a intake manifold from a N/A 4age, which has the t/body on the end of the plenum chamber, I think Tim said that it make it more responsive having the t/body after the supercharger.
Postby soopachargen » Sun Jan 29, 2006 11:42 am
I'm doing the sam with my sc14 gze in my front drive rolla. Im gonna use a custom plenum and im considering a 20v head for what looks like a higher port exit angle on the head which may help to clear the charger better. I'm hoping to get away with a gts-t BOV recirculating into the intake after the AFM and a TPS activated switch for the charger clutch. Still yet to decide on a computer but leaning towards a Link.
When in doubt, down and out.
soopachargen
Postby gdsup » Mon Jan 30, 2006 11:44 pm
this maybe a better view
The throttle body was moved to after the supercharger, like a n/a type manifold, done soley for throttle response.
The supercharger builds so much pressure on lift off that you need really good intercooler piping and joiners, and a large blow off valve.
but please noobies note this or any bov wont work on a standard type setup, and the reponse is so sudden makes it a slut to drive on the street
( bov is freakin noisey tho :P )
this is run using standard ae92 DLI ecu
boogergrom - when supercharging n/a cars at a shop i used to work at, we would use a vacum switch that operated at around 3-5 inchs of vacum via a relay to switch it on, abit less abrassive on the supercharger clutch than tps switching
runs no air filter just bellmouth, good for induction noise + if the air is clean enough for me, its clean enough for the car
gdsup
Postby soopachargen » Tue Jan 31, 2006 12:04 pm
so do you reckon mine will be horrible to drive on the street tim??
any thoughts of a way to get around this??
soopachargen
Postby Mr Revhead » Tue Jan 31, 2006 12:41 pm
yeah but you have built in filters whereas ya car doesnt
Postby gdsup » Tue Jan 31, 2006 6:37 pm
Mr Revhead wrote:yeah but you have built in filters whereas ya car doesnt
well, i usually let my motors overheat, run big ends or det to the point they blow up 1st, so yeah im the sceme of things... :lol:
besides, the supercharger should mince any dirt into very fine particles, and the intercooler will catch the big chunks that slip thru :wink:
bogergrom - They biggest plenium you can have will help, but yeah the instant drive of the supercharger is crazy, bov gets mega surge at half throttle, unless in high rpm its a bit of a on off system - but in saying that i had relitively short runners (perhaps 80-100mm ) and 2.5 in plenium
gdsup
Postby Mr Revhead » Tue Jan 31, 2006 6:56 pm
:lol: well when u look at it that way.....
