vvega wrote:boost cut on the 164 is load based
they have no map sensor so it works it out on flap position and tps signal
its very clkeaver and there is no way around it that i know of
the yank and uk versions have a map sensor
ifyou wanna get rid of it your gunna have to look to a new ecu
i.e 185 or mr2 and rewire the plugs to suit
v
All_Fours wrote:Levin wrote:as most gt4 turbos give up after 100000ks.
Who told you that?
The CT20, as you can see was the first Toyota turbo, and is far from perfect. It has relatively restrictive turbine housing even for the stock horsepower levels of its applications. Lag is also considerable. Maximum flow is enough for about 210hp. Also, it is reported to fail around 100000km no matter how religiously you cool-down after driving and use best oils possible
All_Fours wrote:I think I might know the site you're talking about, did it go something like this?The CT20, as you can see was the first Toyota turbo, and is far from perfect. It has relatively restrictive turbine housing even for the stock horsepower levels of its applications. Lag is also considerable. Maximum flow is enough for about 210hp. Also, it is reported to fail around 100000km no matter how religiously you cool-down after driving and use best oils possible
As you can see, it refers to the nasty old ct20, the ct26 is far better in terms of reliability, even the ceramic ones can last well over 150,000km
