Valve Clearance on a Redtop 4age
Postby no_8wire » Mon Jan 30, 2006 8:16 pm
How much valve clearance?
Its just that I am looking at a 1mm thick head gasket, and was wondering if it would be safe to run...
no_8wire
Postby pc » Tue Jan 31, 2006 1:15 pm
I would think that it's still non-interference even with a 0.5mm head gasket. you should check with plasticene(sp?) tho.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby Mr Revhead » Tue Jan 31, 2006 1:54 pm
yep, check it.
which model redtop?
0.8mm is fine on small ports
and 0.5mm usually is too. but if its had the block or head shaved it may not be
Postby gdsup » Tue Jan 31, 2006 6:27 pm
i ran a 1.5mm shaved head on redtop block 10.5 : 1, was using standard 1.2mm gasket, no clearence issues, had 10 psi too :lol:
gdsup
Postby Truenotch » Tue Jan 31, 2006 7:11 pm
You car is a 7rib TVIS isn't it no_8?
Or are you going smallport?
Truenotch
Postby no_8wire » Tue Jan 31, 2006 9:05 pm
Correct...7rib TVIS block...the bung motor of the 4age family... :cry:
no_8wire
